I cant get over those temps.. that's hot as ****kk, new cars are more confusing.. could we run no thermostat like I did on my old car?
computer would probably flip ****.. lol and pre.. is it hard to remove timing chain cover?? did u hit any snags? I wanted to try it once but was too intimidated :sadbanana:
Its for fuel economy and emissions. In reality its not a problem at all for a daily driver. I mean 248* seems high but with a coolant cap rated at 20PSI, coolant wouldn't even start to boil till past 260, maybe even 270*F. Hell my 87 Camaros factory coolant fan switch (the old school on in the pass side head) didn't turn the fans on till 235*F.
To be honest though, I don't think these cars get hot enough to fully open the thermostat very often. Maybe sitting waiting for a train to pass on a hot summer day. I mean the owners manual does say not to idle the engine for longer than 10 minutes (that's also how long the car will stay remote started without the key in the ignition).
my 70' impala runs 160-170 all day long
at the strip it got up to upper 180s but that's cuz I was all like mashhhhhhhhhhhhhh sit n idle... masshhhhhhhhhhhhhhhhhhhhh sit n idle lol so too much electronics to run no thermostat? can we re calibrate when it opens? or are these temps really optimal? I don't wanna hurt it.. and I still wanna know about the timing cover
Lots of quotes here.
This isn't just for fuel economy. I don't know the year but at one point in either the 1970s or early 1980s it was discovered that running cooler caused fuel condensation on the cylinder walls. This meant both the fuel mixture had to be richer to compensate for it AND it also caused oil to constantly be washed off of the cylinders as well as it contaminated the oil more.
This is why most companies switched to 195F stats. It is also why temps have continued to creep up. Hotter running engines burn cleaner and leaner (which btw also improves MPG and emissions).
Roxxx, your 70 Imapala will run at 170F fine , but will that engine last 200-300K miles like MANY of the engines magically started doing in the 1980s?
The magical difference was higher temps, better oil and leaner fuel mixtures.
As far as I am aware the only time you want to drop the temperatures is when you are trying to run higher boost or compression without knocking.
Sorry for the huge post Preloader.
