Long term update:
I have noticed the amount of oil present in the charger tubes has been reduced DRAMATICALLY from doing this mod. Before doing this, I would have oil present all the way up to the throttle body and standing oil in the intercooler and lower charge pipes. I pulled the lower charge pipe off yesterday and noticed only a bit of oil around the rolled bead on the end of the tube. ZERO oil present in the tube itself. This is after a recent track day too.
The factory employs a solenoid to control the function of the bypass valve. This is a 3 port solenoid with one port connected to the intake manifold, one port connected to the bypass valve, and one port connected to a vacuum chamber located on the bottom of the intake runners. This chamber is fed a vacuum signal through a one-way valve also known as a check valve. This check valve ensures that the chamber never sees boost. In doing this, the ECM can utilize the stored vacuum in the chamber to open the bypass valve when it sees fit. The solenoid is also cycled during WOT. This keeps a portion of the boost signal from ever getting to the bypass valve which mean it leaks boost. Neither of these functions is conducive to performance.
Without getting into a boring-ass back story of how I arrived here, let me just explain what this mod does for performance.
The ECM can no longer open the BPV to reign in trq production.
When you put the pedal to the proverbial metal, you don't have to worry about some or all of your boost pressure being released because of conservative "torque management" protocols GM put in place.
The BPV gets 100% of the boost signal needed to ensure the valve stays shut.
This means that power is not "softened" because a portion of the pressure is leaking past the valve.
Power is now is now immediate, and consistent.
*PHOTOBUCKET IS NO LONGER FREE AND ALL THE IMAGES I WAS STORING THERE ARE NO LONGER AVAILABLE TO SHARE HERE.*
I will rectify this as soon as possible. There are diagrams in the thread that other have made for reference
Here is what's needed:
5/32" hose splice
5/32" vac. cap
3"-4" of 1/8" or 5/32" vac. hose
Either will work. 1/8" will take more effort to get on the intake manifold, but this also means less chance of it blowing off since the intake manifold fitting isn't barbed.
Here is what needs to be done to eliminate the ECM from raining on your performance parade...
BTW, you're going to focus all your attention on the passenger side of the intake manifold. Look for landmarks in the photos such as the alternator or the fuel rail to help you.
If anyone experiences anything weird or contrary to this post, please reply in this thread.
5/32" hose splice
5/32" vac. cap
