Ugh where the heck are you people finding the 5/32" hose splitter and cap?
Stopped by Autozone, O'Reilly's, and Home Depot in my area, but was unable to find anything in that size... :/
Someone helo me hahaha. Ill say it once again I'm still expierencing turbo flutter at low boost psi around 2-4 psi it sounds just like air going through fan blades. But at high psi the bov just blows of as normal with a little different more pronounced sound. I have the green bov spring in the forge bov. Looking for some feedback.
Hm after throwing my DDM Intake back on, I noticed that it only flutters when you start/keep gassing before the bpv finishes blowing off. Perhaps that is what you are experiencing?
Fwiw, you can get flutter even without this mod under the right circumstances.
The limbo between third and second gear driving up Pikes Peak this summer kept mine chattering off and on the entire way.
Maybe that will ease the fluttering minds.
Finally did it. Ended up not needing the hose splice or extra vacuum hose. The green stripe hose was actually easier for me to remove. Pushed it off from the top of the hose with a flathead screwdriver. The vacuum hose was more of a pain for me as the solenoid was cutting up my hand from the lack of space, but I was eventually able to pull it off with enough force.
I was able to reuse the bov hose by unclamping it from one of the wiring harness clamps.
So far, it seems to live up to its hype, so I'm fairly happy.
Haven't heard any flutter yet but I currently have stock bpv and intake on so we shall see.
Thanks for the tips everyone and thanks mpfab for posting this.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
