Gary Grist
I noticed water dripping from the driver's side front door today. Upon closer inspection it was coming from a small rectangular hole located at the very front lower corner of the door. I estimate that about 10cc dripped out. There are similar holes in each of the doors. The front passenger side hole was damp, but not dripping. Both back door holes were dry. I understand that doors can have drainage holes. But the thing that bothers me is the fact that when the doors are closed, the drain holes are positioned directly above a body seam that feeds directly into the rocker panels. This seems a perfect set-up for a rapid rustout.
Are there any 'body men' out there who know if this is the way it is supposed to be or is it a design flaw. I have a 2013 RS turbo MT HB. Should the rocker panels be drilled and filled on these cars?
