Based on rear ends alone, the sedan would have better MPG.
The greater vertical area on the hatch creates more drag with the low pressure area. This drag makes the engine have to work harder at the same speed than the sedan, where the only low pressure area is off of the small trunk surface. But the hatch does weigh less, whether thats enough to offset the drag difference, idk.
but laborsmith, i have to disagree with you completely. These front ends are much more aerodynamic than many other cars than you will see on the road. The windshields are sloped at a greater andgle, along with the hood, which both decrease drag compared to similar cars. Obviously there is a flat area on the bumper, but thats unavoidable for safety standards, you cant have a pointed surface even though it would yield better mpg.
Awesome, so what I've learned is the sedan is more aerodynamic but it doesn't quite matter because they both get about the same gas mileage. Thanks guys, and that makes me want to go test drive both vehicles right now! Which I might do, because It's my day off! haha.
Anybody got a windtunnel we can use?
SonicBoy24, for the sedan to only have pressure drag behind the trunk rear surface, the airflow would have to stay attached all the way to the rear of the trunk. It has to be a smooth transition from the roof to rear window and the rear window has to be a shallow down angle, otherwise you'll get seperation at the roof line and the pressure drag area would be basically the same as the HB.
Here is one of the many articles I have read in the past: Browser Warning About halfway down they talk about pressure drag.
EDIT: Mods, why does my link say "Browser Warning"? The link works fine...
The weight is a minor factor for highway mpg. Sure you have to drag that ~100 lbs weight up hills, but the much bigger factor is the aero drag.
I guess if the sedan really did have ~half the pressure drag, then the rated mpg should be better. The EPA test doesn't spend a lot of time at high highway speeds, but if it were true, the sedan should show 1-2 hwy mpg better? But as far as I know, they are the same...
I'm with you on this, Richie. I'm confident that the sedan will deliver a few more mpg's, too. There are only so many things that the manufacturers can do with the rear of cars without scaring the buyers or freaking out the DOT. The Kahmann rear is the compromise that satisfies everyone; the Prius is the refinement of what the CRX brought to the market years ago. The hard chop-off in the Sonic HB and other cars in the segment don't fit the Kahmann formula, however.
there is a smooth transition, and the rear window isn't that severe of an angle. not tryin to cause an argument, but I just finished a physics class. there have even been articles comparing the sonic hatch vs sonic sedan vs spark.
the spark gets bad mpg because it is so short with a blunt windshield and large vertical rear end that the engine has to work harder to overcome the drag. the same is true for the sonics. im not saying that there is a mpg difference, but if there was the sedan would get better if we were talking merely about the rear ends.
SteveSonic, actually we are not in agreement. I believe the flow over the sedan is seperating at the roof/rear window transition. So the pressure drag would be the same between the HB and Sedan, so the mpg would be the same.
If the sedan really did have 1/2 the pressure drag, then it's highway mpg rating would show 2-3 mpg better? Not sure...
I'm not familiar with Kahmann rear? The prius has a Kammback, named after the German aerodynamicist Wunibald Kamm in the 1930s who researched the smooth tear-drop like shape which is cut vertical. The smooth tapering shape let's the flow stay attached to reduce the area of the pressure drag.
what if we had a small "vent" cut in the center of the "spoiler" to direct air flow down the back window? Like the old suv rear spoilers that helped keep the rear window clean.
That would break up the flow by sending part of the air down and causing to things one the rear window wouldnt be completely useless after 4 miles on a wet/slushy road and it might break up the air flow and reduce drag
