mitdr774
also a dinner prick
If you read what I typed, I never stated that you were blowing smoke. Although technically you didnt make 500 WHP.
What it came down to with Weisco was that they did not want to make a set of pistons without a large production run. It was a normal item that they had produced before. If they had told me that I would have been okay with it. However they decided to lie to me for 5 weeks before admitting that they were not going to make pistons for me. I took my business to local place that makes great custom pistons.
While I never had an Eagle rod fail, I did have issues with pistons scuffing on the cylinder walls. This turned out to be a common issue with people running the same rod as I was. The only possibility we can come up with is the decision on Eagles part to eliminate a small hole in the big end that allows for some oil to spray on the cylinder wall. This is a hole that exists on the stock rod.
