sonic hotness
How do you like them compared to the other ones you were using
ok so i a pair of 6 ohm resistors from v-leds, and i have a set of led bulbs. Originally i tried installing just the bulbs, then i got the error and hyperflashing, so i read your forum and bought the resistors. So i install the resistors, i connect both grounds to the frame of the car with a screw, then run both of the resistors opposing wires to the left and right turn signal lights, i then connect them with the blue clips that come with the resistors. I test the turn signal lights with the led bulbs and i still get the hyper flashing and error. Idk what im doing wrong.....ive attached pictures....ughhhhh! Help please.
Only the turn signal bulbs need resistors, all the others work fine without one. The only reason you need resistors for the turn signals is because they have a fault mode to make you aware of burned out bulbs, the other lights do not.
this can by bypassed with a different flasher, correct?
Just saw your post lol can you post a picture?
Not sure witch ones to get
You definitely know your lights! Your mods are nice and tasteful.
Wow, looks great Andrew.
How difficult was it to replace the headlight bulbs? Any good guides?
Wow they look great
How many led are on the reverse lights?
Do they seem brigher then stock?
i have the same ones with the plasma yellows in the fogs. looks awesome.Here are a few photos of the Northern Stars. They actually appear a little more blue in person, but this is pretty close. Sorry about the poor quality, all I've got is my iPhone and it's not the best at night.
Thanks!
just need black bowties and id get our cars confused lol
