Trevinator
believe me, I am thankful that changing it will be fairly simple when the time comes! if its only about $120 for the part, I would rather buy it myself than deal with the dealership and have them see the mods on the car.
The new motor came with a kit because they had to "cut out" the original blower to replace the motor.
Got it removed and reinstalled. I will have a write up today or tomorrow with pictures in the DIY section.
I couldn't find the write up can you put link in here? Thanks
I don't think he ever made a write up, I looked for a while as well. From what it looks like to me we have to cut the blower motor out, it's not as convenient as the Cruze one.
Seriously? I haven't got under the dash to look, but you can't simply remove the blower motor by removing a few screws and unplugging the electrical connector?
Mine quietly squeaks every so often, when it annoys me enough I was going to see about removing the motor and putting a few drops of oil on what will surely be some type of oilite bushings.
Seriously. On my 13 the blower and housing it mounts to are one piece. I took a air powered bi-metal saw, separated the blower motor from the air-flow housing (cut it out) and installed the new one. Took my time cutting it out and it fell right out, new motor mounted right in the pre-existing mounting holes. Problem solved.
