So.... Cliff notes...
I'm thinking about ordering this stuff up next week. Is the info below pretty much the gist of it?
Parts required for front swap
Bracket - GM PN 13370779 - QTY 2
Rotor - GM PN 13502060 - QTY 2 (or equivalent aftermarket replacement)
Pads - GM PN 13412809 - QTY 1 set (or equivalent aftermarket replacement)
Bolts - 14mm x 2.0 (40mm length) - Flange head, phosphated or similar treatment, grade 10.9 or higher -
M14-2.0X40 Hex Flange Bolt Class 10.9 Phosphate and Oil Finish
9/16 drill bit
General process
1) Remove and support oem caliper, reset piston and follow general brake change proceses
2) Remove factory bracket and rotor. Discard, recycle, etc...
3) Drill bracket mounting holes on spindle with 9/16 bit (should provide approx .011 clearance)
4) Install new rotor and bracket with new 14mm bolts.
5) Re-assemble calipers, new pads... Follow general brake service methods. Clean, lube, etc....
Parts for rear disc swap (non-RS cars)
Left abutment plate - PN 95192914 - QTY 1
Right abutment plate - PN 95192915 - QTY 1
Left caliper - PN 13300883 - QTY 1
Right caliper - PN 13300884
Rotor - PN 13505789 - QTY 2 (or equivalent aftermarket replacement)
Pads - PN 13408579 - QTY 1 set (or equivalent aftermarket replacement)
Left brake hose - PN 95480079 - QTY 1
Right brake hose - PN 95480079 - QTY 1
General process
1) Take old crap off
2) Put new crap on (Note: This process actually works well for me but maybe not everyone)
