I pretty much mirrored the install above seeing how it was pretty much the only manual online for this route. The amp just stays on all the time even when the car is off I have just changed my ground to the same stud you used but that pesky blue light stays on all the time so from my understanding it is the High Level adjustment screw that messes with the amount of voltage that needs to be sent to the amp to turn it on but I haven't found that sweet spot where it turn on when I turn on my stereo. Or it may be something else and I am trying the wrong thing.
My question is mainly, is there anything funny between the HU and rear speakers, like a crossover? I wouldn't think so, since there's no rear tweeters and idk why they'd be split with the fronts somehow. I would very much like to reuse the stock wiring and be done with it.
I have the speakers installed, but I can't seem to find the cables under the head unit that he tapped into for the amp. Below are pictures of the cable that I think is it, but I can't seem to find every speaker wire on that by color. That bundle is connected into the back of the base of the headunit (behind the temp dials) along with two others. Any help as to where the speaker wire cable is located? Is it this bundle of cables? Thanks!
Does this install makes alert chimes louder?
Adding an amp can increase chime volume.
