CheapFuneral
But the autos so better in the 1/4
**** you auto correct!
I'd say they currently lost on cost of fuel but in 6 months gas will be back up with diesel.
Where diesel loses is usually maintenance costs. Not as sure about the cars but the trucks have to do things like fuel filters every 15k.
A year ago - the national average price for diesel was $3.989 and regular gas was $3.457.
Today the national average is $2.864 vs $2.457.
Diesel has sold at a premium for a long time. And will continue to do so for the foreseeable future. This is because of the government mandate for ultra low sulphur content on diesel.
Diesel maintenance costs are steep. I have fleets that I sell parts to that are currently switching from diesel to gas because of the horrendous maintenance costs of the diesel.
I have a 1.4Turbo and run regular unleaded. Have not been able to see any significant increase in performance or fuel economy when trying premium to justify the extra cost.
The benefits of running higher octane go beyond mpg. It's all-around healthier for the engine and allows the pistons to reach full travel before descending back down to "grab" more air. If the mixture ignites too early you interrupt the cycle prematurely and get loss of power.
The benefits of running higher octane go beyond mpg. It's all-around healthier for the engine and allows the pistons to reach full travel before descending back down to "grab" more air. If the mixture ignites too early you interrupt the cycle prematurely and get loss of power. I'm sure this affects longevity of the life of the engine as well... or sounds like it would at least. Do the 1.8 and 1.4t come with different owners manuals? Mine says recommended 87 octane but I still run 93 and even 94 if they have it. Car responds well to it.
Unless your engine is knocking, buying higher octane gasoline is a waste of money. Premium gas costs 15 to 20 cents per gallon more than regular. That can add up to $100 or more a year in extra costs. Studies indicate that altogether, drivers may be spending hundreds of millions of dollars each year for higher octane gas than they need.
It may seem like buying higher octane “premium” gas is like giving your car a treat, or boosting its performance. But take note: the recommended gasoline for most cars is regular octane. In fact, in most cases, using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage, or run cleaner. Your best bet: listen to your owner's manual.
Not only is the fuel cost and maintenance cost higher, but the buy in to get the diesel engine is also quite a bit higher. About $2500 more for the diesel Cruze compared to a similarly equipped 1.4Turbo Cruze. If you don't want leather interior that is standard on the diesel - the difference between the diesel and the turbo is over $4000.
It would be much less expensive to do a tune on the 1.4 to improve the performance than buy a diesel.
...and that is the truth.Any mechanic knows that.If you believe that, and want to pay more for your gas, it's your car.
But, this info is from the Federal Trade Commision...
https://www.consumer.ftc.gov/articles/0210-paying-premium-high-octane-gasoline
More important than using premium fuel is to use a Top Tier designated fuel - which is recommended in your owners manual.
Was just saying elsewhere, it's my 2nd spring with my 2013 and since it's warmed up and she now has 6000+ miles on her (breaking in?), I think I'm really noticing the affect both those factors have in my MPG's. I use the same gas 90% of the fill-ups (Shell 87) and the only other change than the weather and mileage is I switched oil to Mobil One.
I floored it for a while on the highway to see what she'd do, so I ate up some of the good numbers, but on average, higher MPG numbers are there for the same trips I was taking all winter.
Pretty sure over my next few tanks I'll see a nice climb in my MPG's as compared to last year. Hoping anyway.
I noticed at 5k when I also switched to Mobil one. Not sure if it was break in or the oil because I've been using Mobil one since.
