Sneakerfix
I wanted the bov insert to does Zzp offer that?
It's just a flange a flange can be added to any of them
For oil could you tee off at say the bottom of the oil filter housing and just run some steel bradded lines?
Im pretty sure the 1.4 ic will fit because it's the same frame so body wise it should at least be marked where the ic would bolt up
http://youtu.be/Ds2HwwaHnyE
This video is a Cruze 1.8 and I was going to run my piping the way he did
That's my other question sensors and stand alone ecu what to pick?
I was wondering what to do because it seems like the fan would be in the way if we used the Opel corsa turbo
Run the turbo and manifold from the corsa
Piping 2.5in down to the grill and up to the throttle plate like the 1.8 Cruze video I posted
I'm still worried about oil lines how would that manifold help to run oil lines
Can u pm me and help me you said use the parts off the corsa but I'm not sure how
How will the intake manifold be used to pump oil?
