CheapFuneral
That would give u an idea of what you are actually picking up from the intake as well.
**** you auto correct!
This is exactly what I've been wanting to know. Keep up the good work sir. I'll be waiting for an updateWell we took it to track yesterday with the first mod we did which was borla cat back system 140487. No noticeable difference over the stock exhaust. Conditions were almost identical to the last time it went 15.30. Amazingly the 60 ft picked up .1 to 2.17 from consistent 2.26 but it didnt pick up anything up top like i thought it would. So this week we are switching from scr 8040 to trifecta elite tune and putting on the k&n intake and we will try that next week
To the gentleman that I raced tonight from this forum, very nice car you have. We raced at Cecil County Dragway. I was in the 2015 Honda Fit with a homemade intake and exhaust setup. That is a beautiful Sonic you have.
Do you know his name? How did u do vs the sonic?
Is Stratton still #1 with 13.77?
(Bad launch with wheel hop, missed 4th, intake temp was 145 degrees), the second run I ran a 15.448 (forgot to re-disable TC, which didnt seem to make much of a difference in my 60',
You shouldn't need 4th gear if you're on the stock wheels and tires. Definitely pull the abs fuse next time to disable TC.
The fuse you would want to pull is the top left fuse in the panel under the hood near the battery. You can leave the fuse in the fuse puller while its out, There will be warning lights on the cluster the entire time its out and the car will beep and make noises at start up.
Thanks Foxbox! Even in the RS you dont need 4th? i was having to shift right at the very end which im sure was hurting my time. I was trying to find the right abs fuse to pull when i was there but wassnt sure which one it was. Under the hood fuse box there are 3 labeled as abs, or is it located under the dash?
EDIT: Looks like it is located here,
What's ur modsAt track now, just ran 14.798 at 94 with 2.18 60
