Frizodanizzo
Came up with a P2227 barometric pressure circuit code wanted to try just replacing the mass air flow sensor anyone have any suggestions that have come across the issue before.
Did you clear the code. Did it come back
Are you tuned? Lemme know how this works for you.....The code never displayed as a check engine light, it would only be pending then when you turn the car on again don't even drive it's cleared from pending again. The scantool has a help site I looked up the code and apparently boost sensor/intake temperature sensor right after the intercooler is the most likely fix for the problem. It's coming only cost 26 bucks so it won't be much of a waste if it doesn't resolve it.
I threw this code a week ago, hit the delete, prayed a lil bit, and it did not come back. But if it does..... would love to no water u did
Sent from my SM-N910T using Tapatalk
So far no issues, I replaced the boost sensor/ air temp aka air charge sensor fuel trim is way lower than it was. I'll let you know in a few days if I have anything come back mine was contaminated with oil.
