Frizodanizzo
I always noticed my sonic ran slightly richer stock, put a cold air on it it runs totally lean high + numbers gray spark plugs. Stock air box - numbers never had codes with these except the lean one p1101 take off the cold air goes away. This was even after the boost sensor, maf, inter cooler piping vacuum lines all brand new. So there's no issues and no codes at all with the stock box but like I said little rich. Just wandering if that is normal used to seeing cars be closer to a very true air fuel ratio.
