Goto the previous pageIs there a new link as the ones showm r busted
Or goto page 54, where there are photos and diagrams...If your having issues I can snap pics when I do this again had to revert for some warranty work and will be going back and bypassing in the next week or so
Sent from my SAMSUNG-SM-G935A using Tapatalk
Does anyone know where I can get the pictures for the process?
go to page 54, where there are photos and diagrams...
Try scrolling up, or going to the last two pages if using a computer instead of the app?Does anyone know where I can get the pictures for the process?
P2261 Bypass valve stuck ? I bypassed the Bypass valve solenoid that is attached to the manifold. The wires are still connected. That would be why I’m seeing the P2261 correct?
Went straight from the manifold port to the hard vacuum tube for bypass valve.
Am I understanding the bypass valve code correctly ?
What issue are you running into?Picture 1 is bypass valve, second picture show valve at turbo I left that alone any help I tested valve that I bypassed and works anything else I should check thanks
