MidnightClub3
Does this still need to be accomplished if you're BNR tuned or does the tune accomplish the same thing?
I never wrote back. I did the bypass. There is no change in power delivery or anything. But at least i could get the boost gauge installed without the system giving any errors so thats still a thumbs up for this mod in my eyes.
Sent from my SM-G925F using Tapatalk
Holy hell gonna have to do this when I finally have some spare time again lol......EDIT:but on that note I noticed the long term update in there stating that the oil levels seems to change dramatically isn't that a bad thing?
As a side note I broke what I think is the solenoid you are talking about in this mod when I installed the new turbo. I am talking about the solenoid attached to the turbo assembly. I broke a plastic nipple off. I replaced it with the solenoid that was on the original turbo.
Hey all,
I attempted the bypass this morning and it was a FAIL. I was able to get the green/black hose off of the IM but when it came time to remove the vacuum hose off of the solenoid the space was too tight to maneuver. I didn't feel confident that if I was able to remove the hose that I would be able to cap it so I reverted back to stock and said "maybe another day."
I also thought about running a new 5/32 vacuum hose from the BPV to the IM but I couldn't reach the hose clamp on the BPV because it's facing down! Unfortunetly, there was even less room to maneuver around at the BPV so that option was out.. Unless I could remove the wastegate actuator I'd have more room but that AIN'T happening. Maybe one day if I have more time I can unbolt the IM and tilt it a bit to access the solenoid and try again.
Oh well, just have to get the BNR tune next!
