sonic-image
OH dude that is mint! I can't wait to see how you make out with it.
Sent from my SM-A520W using Tapatalk
figure out how to do this and i’ll get one too ross
My wheels should finally be here next week. So, I will be able to start my exterior appearance project!
Also, the PVC fix is installed into the ported intake manifold with ported throttle body. Ready to bolt on whenever I get some time.
This intrigues me. I've heard that the ported intake won't run properly without a tune. Also my dealer told me that PCV modification would void my warranty
I'm using a ported (tumblers grinded down) intake manifold with the V2 PCV mod (routed to brake booster) on stock tune for about 3k miles with no issues at all. It was initially thought that you did need a tune, but you are perfectly fine either way.
Noticeable difference? None at all. THAT is where a tune would really benefit this mod. I've got a spare one listed on the classifieds page if anyone needs a new IM and doesn't feel like doing the work, too.
Loving the build so far Nataphen, good work!
I may do rear discs when it’s time to change brakes, but I’m not going out of my way for it. Still on the stock tune for now. Going with BNR eventually.
That is a good color, even if not for your application! What type of tint are you using? Link?
Sent from my LG-TP450 using Tapatalk
Can't speak to their tint but Vivid makes an excellent vinyl wrap. Quality stuff and easy to work with.The color may look fine on some colors, but it clashes with the gray for me. I’m not trying to knock the product by any means. I ordered this from Rvinyl, but I just checked, and their website is down for maintenance at this moment. Should be back up soon I’d guess. It’s a wet application vinyl, and it looked pretty good. You really have to work it on the curves of the light though, and having someone to help blow dry and stretch it is almost a necessity.
The new one I ordered is from Vvivid, and it’s a dry application type. I checked up on it, and it’s the only tint about which I’ve seen the true black look mentioned. One installer on YouTube said it’s the only one he’d ever seen that wasn’t brownish on a clear light. We’ll see soon enough.
What are the dealers messing with you on? I'm so thankful my dealer takes care of just about anything without any hastle.Honestly at the stage you're at it kind of makes more sense to abandon your warranty than to try and keep it and probably get refused anyways....I'm almost stock and still having problems with them. Tempted to try and get my extended warranty canceled and reimbursed. Though I doubt that'll ever happen.
