palpullero
Just wanted to show off my transmission cooler install. I hope to make a DIY later.
1. Bumper had to come off (note: I had to remove more than the bumper, but I'll detail that later):
2. Research the area for the cooler install:
3. Install the cooler (you will need to intercept the return fluid line; more details when I make the "DYI"):
4. Wire the switch and relay (relay not shown and the second switch is for my radiator fan switch bypass mod):
5. Enjoy cooler temps!
Note: I changed the transmission fluid to Amsoil Signature Series ATF Fuel Efficient after the installation and I never seen my transmission fluid temp so low - it never goes above 180 degrees F, even here in Florida. I changed the fluid from original fill to Liqui-Moly ATF 1800 at 38K miles and again at 68K miles; I performed the install at 70K. With Liqui-Moly I saw temps sometimes past 200. I use a ScanGaugeII to monitor several items in the car. Same roads all the time (this is my commuter vehicle). I feel the combination of the cooler and Amsoil is a big winner; I would recommend it.
When I get the time I'll make a DYI.
Cheers!
Cheers!
