My 2012 1.4l turbo is a mess I had 3 leaks and took out the head gasket.... So I decided to take this as a challenge and install a rebuilt head, timing change guides and tensioner. I also replace the water pump and anything that could leak 9coolant and oil) went back to factory clamp (the previous owner used the screw type clamp that also failed). Car was running before this repair now its a a mess and I can't start the car (it does turn over just won't start)... I am in time, I checked 7 times I also have compression... I decided to get a new scanner and see if I have any codes and guess what I have the following p0118, p0108, p0107 and p0697. I have found the definitions of these code and have been trying to figure out why these codes just decided to appear... I am at a total loss right now and going crazy trying to figure this out. I have now decided to start removing the harness and intake to check every connection to see if something has been broken... If anyone know what's going on or how to resolve this please let me know.
TIA
TIA
