laborsmith
If going w/o a resonator there would be room for an electronic exhaust diverter, I have used NoWeeds version with satisfaction and QTP reportedly has a good product also.
Laborsmith
Laborsmith
Here are some pics of secondary cat delete please dont mind the piping after the flange its only temporary till I get the stainless steal mandrel bent. Also a pic of the muffler delete. Once again please note the piping after the flange I installed is only temporary until I get my stainless piping.
Are you essentially down to one cat and straight factory pipe? Your muffler delete is something that I would consider but think I would rather go with DDM's test pipe (mid pipe with no cat) so that I could throw the factory secondary cat back in if I needed to bring the car in to Chevy. Or have you removed the factory cat and built from there?
I removed secondary factory cat and built from there but still have some factory piping from the resonator to axle pipe including resonator. I know I voided my exhaust warranty but I really dont care about that. There is no O2 sensor after secondary cat so it will not set check engine light. I did also put a stainless 2.5 inch flange there so the rest of the piping can go right on when I get it and so I can remove it easily if needs be for service. I am building this car with the ability to service it in mind. I work on cars for a living so I don't want to make mine a pain in the rear. I did notice small power improvement even though the factory piping is still on there. I am waiting for my next pay check or maybe the one after I found a stainless mandrel bent universal kit which I am going to build the exhaust out of. Its also 2.5 inch piping. It will cost me considerably less to do it myself and I have pipe expanders and have a metal table saw on order. I dont know if you noticed but at the end of your second cat before the flange it reduces to 1.75 inches. I dont think it would be smart to buy a whole cat back exhaust unless you remove that kink. When all is said and done I will post pics.
Since I work in a shop and have a welder I was thinking of using Jegs Universal kit to make my own exhaust. It is all mendrel bent and its only a matter of making the correct cuts. I have exhaust hangers the only thing I would need is another 2.5 flange to replace the one at the rear of the second cat. I dont know why but it is reduced to 1.75 just before that flange. JEGS Performance Products 30671 JEGS Street Rod/Muscle Car Exhaust Kits Also my girlfriend has a sedan and the only difference from the cat back to the hatchback is the length of the tail pipe. I cant understand why people can't just make the kits for sedans already. Its literally adding a few inches of tail pipe.
i got my exhaust done at a exhaust shop for 125 bucks 2.5 inch pipe no resonater and a straight through thrush muffler sounds awesome looks great too btw this is on a 1.4 turbo
yup stainless pipe and the muff no res
