TurboTechRacing
Supporting Vendor
Turbo Tech Racing Now Has Upgraded Clutch Kits!!!
:banana:
3 stages available!
Performance Clutch Kits - Turbo Tech Racing
:banana:
3 stages available!
Not badly priced will deffently buy a stage 1 when my stock one craps out
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Some need the stage 3 already. ;P
-Eric Smit
Will the stage 2 hold 250 consistently? I think the extra $50 for the 3 will be more peace of mind.
-Eric Smit
I think for $50 more I would get the stage 3.
Also I always think of it this way:
If you get an item, and are always running it right up to the max, it seems to wear out faster. If you get something and run it half of max, it last a long time, as you are not stressing the object nearly as much.
Isent it with the higher stages it outs more stress on the transmission ?
Not exactly when it comes to clutches. The torque kills the trans, if stage 2 clutch is not slipping with your given torque, then stage 3 with the same given torque will not add any additional stress to the trans.
This is great news.
What's the weight of these clutches vs stock??
Are you planning on making a lighter flywheel for the sonic or having something like a cor exchange where we send in stockers and you send us back a lightened o.e.m. flywheel?
-tyler
This is great news.
-tyler
