Got my injectors installed, ran the flash, so I'm alcohol capable now. I ran a data log on my standard E10 93 with the new injectors, then went and filled up with E85, 8.2 gallons, which means I had about 4 gallons of E10 left, and which means I'm now running E60 (or less, since E85 on label may be as low as E70).
Starts rough, and idles poorly, other than that it works fine. I can't feel "more power" on the butt dyno, but I am now smoking tires in first without turning the TC off.
I'll put up an install post later, if I can't find one from Preloader. Took lots of pictures.
MPG on the UG is reading pretty much the same as before, like Preloader I do not believe this to be accurate, but if it is... $3.24 per gallon is pretty sweet.
I really must have the UG set up wrong, by the way, as it continues to top out at 199.9 torque no matter what I do.
