ThatTmoGuy
IIRC his stocker was fine, He just wanted the red pill so he needed the better clutch.
80-100k or more depending on behavior. My pops has gotten 200k out of one on a Mitsu, but then again he owned a Trans shop for 20 years and has major skillz.
Sounds like if I drive it like I stole it, then the life could be shorter. If I grandma it, no worries
OPPOSITE!!! The rougher you use it the better. Trust me.
Yes really. The quicker you can engage the clutch (rough) the better. It's the friction grabbing from smooth engages that wear it out. "Dumping" the clutch is the best way to make it last, not to mention a much funner way to drive......unless your wife is in the passenger seat.....or even worse, your lap.opcorn:
What about holding in the clutch at a stop light
Not what I ment at all I mean pull up to a stop light push brake and cultch at the same time
But the best behavior is to put it in neutral and use the brakes at stop lights.
