I have 2014 Sonic LTZ with 95k miles. I started looking at my first aftermarket parts to install. I bought the zzp CAI and the high voltage coil pack with new spark plugs. I was super excited as it was my first time working on this car. Everything seemed good but after driving to work (around 20 miles) I had smoke coming from the engine block. I did some research and settled on it being the valve cover gasket. To be sure, I put the stock air intake back on and the problem persisted. I believe the CAI may have been the final straw for either my turbo or my pcv system. After intallation of the valve cover gasket I put the ZZP CAI back on and the turbo noises were awesome (durrrrr turbo noise). Then when driving it shifted hard, popped the engine light, and I believe went into limp mode. Still had to get to work so I was driving the whole time basically under 2k rpm. My buddy ran the code and it was a P0299. Took it to the shop again and asked them to check out the pcv system and check what was causing the engine underboost. They diagnosed that the wastegate was getting stuck and if the problem persisted the turbo needs to be replaced (why not only the wastegate??). Doing more reading and watching videos I was almost certain that they misdiagnosed it and the pcv was the problem. I’m not a mechanic but I heard the valve cover gasket thing had happened to others. I bought the ported intake manifold from zzp as well as the pcv system upgrade. From earlier when I had taken the car in and they said the turbo would need replaced, I had bought the Chinese turbo from a-premium for 300. I was gonna return it and save the money but my friend that is a mechanic said my turbo would need replaced in 20k miles or so. Currently having the turbo installed and I wanted to ask your guys opinions on my situation and if you think I’ll have more problems if I put the CAI back on along with the ported intake manifold and pcv system upgrade. Thanks and sorry if this post sucks.
