CjCsonic
Encore bracket: 13372779
Dealer list for two is $68.24
Been freakin swamped at work, thanks for the part number. Hopefully with my weekend off I can call and get them ordered. Fingers crossed on good availability.
Is a redrill the kind of thing that any machine shop should be able to do?
sorry to be a party pooper.
but the rotors from the encore and the cruse diesel are not the same bolt on spcss.
yes they are bigger, yes they are 5 bolt , but they are 115mm distance.
our sonic bolt distance is 105mm..
i have been looking for a brake upgrade of this kind for a long time.
still have no solution.
the same brakes are used in the opel astra (j), and many other platforms.
but the bolt distance is different. 115mm VS 105mm
i haven't check this in real life, only from the spec sheets, so i will be happy if someone prove it to be wrong...
the brackets swap is a 10 min work.. so it will be a great upgrade for a cheap price.
just curious, but would this fit in the stock 15" aluminum rim?
I actually have the sonic and Encore/diesel cruze rotors where I work. The bolt pattern is the same 5x105 matches perfectly even the height of the rotor.
Nice.
I was looking at the GMPP big brake kit but they discontinued it, I just can't see spending the money for the Brembo kit. ZZP's kit looked alright but I'd rather go with OEM parts since you'll never have to worry about finding replacement parts down the road.
So this really looks like a simple matter of picking up the rotors, having them redrilled and picking up a set of caliper brackets?
The Zzp rotors and none oem calipers are trash not sure why they just don't use the oem or better aftermarket parts.. And yes the brakets are the only good thing about the kit.. But for a person that just wants the look of rear disc over drums its a good starting point.
Here's the left bracket. BEEFY!
Would these brackets works with the pieces supplied with the ZZP kit? I would prefer to have these on my car.
