tainopayute
If you decide to install these latches on your bumper, you can buy a smaller set of latches or you can even go with a bigger set if you'd like. The holes that you will drill only have to be big enough to fit the latch that you choose, however, the holes have to be drilled in an exact location in order for the latches to line up perfectly with the pins.The hole looks quite large and requires that large black retainer/push thing.
Is the hole so large so it accommodates the push retainer?
Or is the large hole needed so the bumper can be lined up easier..one needs some loose tolerance?
It looks good... great instructions.. 3/4 inch hole..at that point one is totally committed to finishing.
Sent from my SM-G920T using Tapatalk
