Adding Quick Release Buttons to your front bumper.
Okay, I went out and did the same thing that Beastlick did and added the bumper quick release latches. If anybody wants to also give this a go, here's how I installed mine.
Now I will say this, I will only recommend that you do this on your own if you're mechanically inclined. The modification is not hard at all but if you make one small mistake, you might have to end up replacing your entire bumper so proceed with caution.
What I did first, before beginning the process of installation, was to study the way that Beastlick installed his. Here's the link to his set up...
http://www.sonicownersforum.com/forum/showthread.php?p=313255
I will do the best I can to complement what Beastlick already posted a few months ago. I will also say this, when I first installed my latches, I did not take enough pictures so what I did here was to go back and remove my bumper all over again so that I could take a few pictures for this write up.
Okay, once you have ordered and received your latches, what you want to do is to remove the front bumper. If you have fog lights, don't forget to unplug them before you pull the bumper away.
Once you have done that, go ahead and replace the bolts that are located right below the plastic brackets with the quick release latches.
Now you're going to take your measurements so that you can drill the holes in your bumper.
Using a square ruler, measure the distance from the corner of the wheel well on your fender to the latch and then measure down towards the latch.
I found this measurement to be 8" 3/4 from the corner of the wheel well to the spot above the latch and then 2" down to the latch but don't take my word for it, please double check for your self.
Now for the next step you're going to need a marker, a small drill bit to drill a pilot hole, and a step drill bit.
You are now going to make your marks on your bumper. Using the same square ruler, measure from the corner of your bumper towards the front and then measure down to make your mark.
Once you have made your marks on both sides, double check and triple check your measurements before you drill.
After you have confirmed that the marks are accurate, go ahead and drill your pilot holes.
Then using your step drill bit, drill the main holes for the latches.
Once you have done that, go ahead and install the latches. Before you replace your bumper, loosen the latch bolts so that you can adjust them with the bumper back on. Install your bumper.
Once you have installed your bumper, make sure that the latches hooked on to the bolts. For the next step you're going to have to remove the plastic covers that are inside the wheel wells so that you can adjust and tighten the latches from the inside.
Once you have adjusted the latches, plug your fog lights back in, put the plastic covers inside the wheel wells back on and installed all your screws and bolts back on.
Enjoy your new quick release buttons.
Sent from my SM-G920T using Tapatalk
