Iraqivet's build thread...
inm
iraqivet
Banned
just going threw this post and noticed this.. I have a 2002 883 sportster owned it for 3 years now.. I have rode it to bike week in dayton from maryland two of those years straight threw.. around 17 hours it took me.. I have put over 30,000 miles on my bike i ride it year round. :banana:
30k i two years is good.
iraqivet
Banned
well if the snow holds out for this week and my dam parts ever show up from GMparts.com i should be starting to put things in i have to roll and pull my fenders and rear qt this weekend. and if all gos well she will be on the new coils and wheels buy the 6th
iraqivet
Banned
ok update gmparts.com sucks they said 3 days to prosses then 5-7 days to ship. then i fine out there a hour and a half away. picking the car up in a few hours and then driving down to get my parts.
5-7 days to ship my parts 80 miles FU gmparts.com
14T6MT
iraqivet
Banned
Ooooohhh...I know ZachTullier (sp?) pulled his fenders a little bit, but I'm excited to see how it looks with a more aggressive roll and pull. Our fender flares are one of my favorite design details on this car, on the hatchback at least. The hatchback already looks so fat relative to its length.
Be proud Iraqivet. I'll be checking this thread multiple times per day.
thanks it looks like the pulling will be done friday. so ill put pick up.
also are you going to the sonic meet may 11th?
14T6MT
iraqivet
Banned
I should be able to make it but I may not arrive until 3pm-ish. Although, I may trade a shift at work so I can show up earlier. By then I'll have my springs and exhaust on and hopefully a few other goodies.
well let me know if you need help.
Preloader
The M32 Martyr
iraqivet
Banned
Any plans to get the back lower?
I'm about as low as you just posted in the front, and would love to go even lower, but no until I can get the back down to even the drop.
I have just the Pedder coils in back. I removed the kit perch height adjuster completely.
i have a custom set of BC coils with shorter springs and dif cartages in the shocks. aka the lowest set up made. the rear is low. and even
Preloader
The M32 Martyr
iraqivet
Banned
Can you measure the TDC of the fenders?
Mine is 24" in back and 23.5" in front. I would like to keep the 1/2" rake and go another half inch lower all the way around.
23.4 rear and 23.2 front
and i just put them in so they should settle about a 1/4 inch or so. and i have a inch and a half lower i can go in the front and prob get a 1/4 more in the rear
Preloader
The M32 Martyr
iraqivet
Banned
Nice! Thanks for the numbers. I knew yours was lower, because my front lip is just under 2" off the ground. I realize the only way I'm gonna get the back lower is with custom coils. I had already planned to get higher spring rated coils for the back, but while I'm at it I'll try to get 1/2" lower ones.
How do you order to get the right dimension? Do I simply tell them, gimme some 8k springs but 1/2" lower than the last ones?
well thats up to you.
i did a lighter spring but changed the cartages in the shocks
what do you have from the ground to the bottom of the lip in the front
and from the ground to the bottom of the rear bumper
Preloader
The M32 Martyr
iraqivet
Banned
I have 1.9" in front (rubber dam). 8.375" from ground to back bumper.
Also the frame rails are about 3.25" off the ground.
The reason I want stiffer rear springs is because the Pedders spring rates are unbalanced. The fronts are stiff and the rears are too soft, causing noticeable understeer.
the springs settled a bit today ill get measurements tomorrow on mine.
