christopher.s.terry
The oil filter housing he got from the 1.6 has an oil feed port built into it.
So I looked at my 1.4 oil feed line, and it is much shorter than the one for the 1.6 and likely won't be an option.
You may be looking into custom oil lines if you can't score one from a 1.6.
Personally I would run custom feed/ return lines with braided lines. I would think if the factory lines are hard lines u may encounter headaches. To each his own, where do u plan on tapping your oil feed from???
Thanks PRELOADER, i joined the vxr forum as well so maybe i can get some help from them. Would u have any ideas how to run the lines??
