Happening with my '20 RS currently, dealership has spent 10-12 hours and don't have a clue. Want me bring it back again today. Wish I'd kept the '17 Sonic Hatch.Ok, can't seem to find this on here. When I park the car and have had my radio on, it would normally shut off when I opened the door. Well I just got home and even after door was opened with key out , and even after arming it, it was still on. When I opened the door to manually shut it off, that's when it finally shut off. I don't want to forget and drain the battery....anyone else have this happen?
That was the case from 5 of 2020 until last Saturday. Opening door does NOT power off radio. Dealership doesn't have a clue. Very frustrating.dermo,
Please see pg. 9-19 under Driving and Operating, RAP The Retained Accessory
Power (RAP) Sonic vehicle accessories may be used for up to 10 minutes after the
engine is turned off:
. Audio System
. Power Windows
. Sunroof
The power windows and sunroof will continue to work for up to 10 minutes or until any door is opened. The radio will work when the key is in ON/RUN or ACC/ACCESSORY. Once the key is turned from ON/RUN to LOCK/OFF,
the radio will continue to work for 10 minutes, or until the driver door is
opened or the key is removed from the ignition.
Hope this helps!
Vanessa
GM Customer Service
Was this fixed? Just noticed a few days ago mine is staying on after shutting off car and opening door. I also have a 2020 RS SonicThat was the case from 5 of 2020 until last Saturday. Opening door does NOT power off radio. Dealership doesn't have a clue. Very frustrating.
They say a" bulletin" indicates the problem but update will not successfully load.
