CoHPhasor
Hit the rubber In the socket with a shot of WD-40 and see if that gets you the grip with easy release.
Exactly. You've got to lick it before you stick it.
Exactly. You've got to lick it before you stick it.![]()
At college I had to sit in on a seminar on aircraft sparkplugs by Champion (it was as thrilling as it sounds). They said to only use a small dab of antiseize at the start of the threads. The end goal (as CoHPhasor points out) is an overall thin coating on the threads.
I also recommend feeler gauges.
What prompted all of you to run out and check spark plug gaps? What was the car doing anyway. Was it rough idle?
Alright, I realize I'm far too much of a wimp when it comes to mechanical stuff. Aside from almost slipping up and messing up the electrode on one, that wasn't bad at all. Here's the news:
My plug gaps were .020 .025 .018 .024, a bit off from the factory specs of .028. After reading through the thread on CruzeTalk I got bold and made the gap a little larger. I didn't go for .035 like most there recommend but went for somewhere between there and .030 which some there said is the sweet spot for improvement vs. risk (.032 for me). I also went ahead and disconnected the battery to reset the fuel trim according to some other advice from over there.
The result is quite nice. The throttle is much more sensitive than before and responds to even a slight tap on the pedal whereas before it took a decent push to get it going. A tap on the pedal that used to raise my RPM from idle to about 1100 or so now gives it about 1500 for example. Gears are easier to change since my mind doesn't have to try and compensate for throttle lag. Quite noticeable. Overall acceleration seems to be about the same, just perkier from the start in lower gear.
Before I did this, especially if I was in a lower gear, the car would kind of bump along when it got below about 1500 almost like it was fighting a stall, though not as harsh. I wasn't sure if I was just driving a manual all wrong (still always possible, I still suck at it) or what but that's gone now. It's smooth unless it dips below idle and even then it doesn't lug as bad. It's easier to get the car in first now since the engine doesn't struggle nearly as much under load at low RPM. Between this and the K&N filter I put in it's really grown some cohones
Those were my results as well, the car is just much more enjoyable to drive. It no longer makes you groan when the gear change jerks around and "stumbles" trying to acclerate. It just works like you expect it to, which is actually asking for a lot these days.
What prompted all of you to run out and check spark plug gaps? What was the car doing anyway. Was it rough idle? Please let me know. I am aware that there are other posts on other forums but it seems there are people on here that are not really finding too many issues.
Please let me know. My idle is rough and dealer can't seem to fix it.
Ed
This is so easy that there is absolutely NO REASON to not check.
Go check the plugs, see how it goes.
Yes it is.
