Big Turbo Sonic
My build started with an automatic 2012 Red Sonic Sedan. I absolutely hated the sedan and the automatic so fall of 2016 I sold the sedan for my 2013 Granite Black Hatchback. Manual transmission. So lets get to the fun stuff....
The biggest mod I had done on the old car was a turbo swap to a GT2056. In the down time from buying the new car I sent the GT2056 out to get rebuilt and had it machined to fit a slightly larger compressor wheel from its older brother GT2560R.
So my mods are...
1. GT2056 w/larger compressor wheel built by Work Turbochargers.
2. MPFab custom exhaust manifold
3. MPFab custom down pipe.
4. MPFab custom intake pipe w/MAF honeycomb.
5. MPfab Intercooler.
6. MPfab anaconda.
7. MPFab Battery Tray
8. MPFab DRS.
9. MPFab Anaconda
10. MPFab Ported throttle body
11. MPFab/HPTuners Tuned
12. MPFab Oil Feed Adapter
13. MZ0 Transmission
14. ZZP cat back
15. ZZP 12" Front brakes.
16. ZZP Rear disk break conversion.
17. ZZP Rear Sway Bar
18. ZZP gauge pod (not in use)
19. 52 lb injectors
20. Ported intake manifold
21. Bypass the bypass
22. Spec stage two+ clutch with aluminum flywheel
23. Autometer cobalt gauges: wideband, boost, & water.
24. Summer wheels: Klutch ML7 wheels. 17 x 9 et 30 Drilled from blanks to 5x105. Tires are BFGoodrich G-force Comp 2's 255 40 17's Approximate finished Wheel & tire weight: 46lbs
25. Other wheels: Sparco Assetto Gara. 17 x 7 et 40. 205 50 17 Sumitomo Tires DESTROYED. I dont know what I am going to do with these wheels at this point. Wheel & tire weight: 37lbs
26. Winter wheels: 17 x 6.5 oem ltz wheels with 205s 50 17's. Wheel & tire weight: 41lbs
27. Turbo tech racing solid trans mount.
28. Pedders Racing coilovers.
Some other stuff I may want to complete the build..
1. Carbon fiber parts
2. Solid engine mount
3. BNR short shifter
4. BNR shark fin antena
SOTM: April 2017
Pedders Coilovers With Klutch ML7's
Dyno:
Pedders Coilovers With Sparco Wheels...
Stock springs & struts with sparco wheels...
So my mods are...
6. MPfab anaconda.
8. MPFab DRS.
9. MPFab Anaconda
14. ZZP cat back
19. 52 lb injectors
SOTM: April 2017
Dyno:
