Preloader
The M32 Martyr
Hoping to stay on target to be installed by September.
The manifold will have the flange pointing down. But the orientation of the comp outlet will be pointing straight forward in that position. The only way to "clock" the comp housing to point the outlet down, is to replace the WG actuator with an aftermarket actuator that mounts to the CHRA instead of the comp housing.
