I think that the ZZP rear sway bar is fairly new to the market. Not a huge fan of the torsion beam brace, and I assume a sway bar would provide a little more leverage. Has anyone installed this? If so are there notable improvements in handling?
UPDATE: I bought the zzp rear sway bar and it has made a huge improvement in handling. The body roll has been significatly reduced, and turn in is much improved. Install was less than an hour which included getting the tools. Easiest way to do it is unscrew the lower shock absorber bolts, and jack the car up. The tires can just sit on the ground, no need for a spring compressor.
Thanks for all the input!
