Blue Moon Sonic
You know. I wouldn't mind have braided brake lines made by MPFab for the sonic for all 4 corners. Let's make it happen guys
Ok so you second that motion do we have a third and a commitment from mpfab? Not like he's not already working 14hr days right, lol.You know. I wouldn't mind have braided brake lines made by MPFab for the sonic for all 4 corners. Let's make it happen guys
Ok so you second that motion do we have a third and a commitment from mpfab? Not like your not already working 14hr days right, lol.
Both myself and Stew are awaiting our parts to arrive should be this weekend or next week.Do we have any success stories and pictures yet?
I love those wheels what brand are they?
I can't think of another way around this if anyone has any input please go ahead and post up your ideas.
I thought of that but idk how i feel about using a helicoil on the bracket like that. Maybe a threadcert but they are expensive as hell from my experience and hard to get. 14mmx2.0 by the way, thats what you asked for.What's the thread pitch? Reason I ask, is because I've noticed that often a helicoil repair kit will have you drill and tap up to the next size, and the install the insert into that. For example, an 8mm x 1.25 repair kit will have you drill and then tap the hole with a 10mm x 1.25 tap. If the thread pitch is the same, you may be able to screw 12mm x 1.75 a helicoil insert into the 14mm threaded holes in the bracket. That way you can use the stock hardware and no drilling is required.
I don't think you can use them like I mentioned if the thread pitch is different. The stock 12mm bolts are 1.75 thread pitch.
The threads are on the bracket itself, not the spindle. If we drill out the spindle to 14mm we'll be done.....I have an idea. Instead of drilling out the hole for the 14mm bolt and putting in a helicoil, why don't we have a bracket made in the same fashion as the encore but for our bolt setup. The helicoil idea is a very good suggestion and would use it in a pinch unless you are uncomfortable with drilling and retapping the hole with an insert put in for the stock thread pitch.
Or if i find a helicoil or thread cert to go from 14x2.0 to 12x1.75
