SSpeckerwood
Looks good. U thought this was a DIY on how to install a breathalyzer.... Guess I'll keep a searching. Lol
The idea behind doing this is that the 1.4T was designed as a flex fuel engine, complete with tables in the ECM, but that inexplicably GM decided not to offer it as such. By adding a sensor, you can tell the ECM, on the fly, exactly what mix of gasoline and ethanol you are running, which should make it more efficient in today's mix of pump gas that runs anywhere from E0 to E10... but which should also allow even more ethanol.
Without installing bigger injectors and retuning the engine, there's really not much point, but BNR is now offering the injectors and tune; the problem is, without adding the sensor, you have to commit to always running E85, or you have to empty your tank, switch to the different gas, flash the different tune, each time you want to change.
With the BNR kit plus the sensor install, it should be possible to really run anything; E0, E10, E85, or even a random mix, say half E10 half E85... in other words to fill up on one gas when you've got half a tank of something else.
The sensor was Part number 13577379, the wiring harness, I'll have to dig around for parts numbers, but basically I called them back up and said "I need the wiring harness that plugs into that part I ordered earlier"
Even if you don't install this sensor, you'd still want to yank that rubber hose and replace it with an alcohol ready one, if you were doing the E85 conversion.
Any chance you got the part number from Buick for the harness?
anyone else think this was for a breathalyzer
peckers on my level.
The comp sensor arrived today
When the injectors and tune arrive I'm just going to run full e85 and take my time getting the sensor looped in.
One concern I have is that the sensor's original location on the CXL was right after the fuel tank, and we are installing it much closer to the intake.
On the CXL, the ECU likely lags the fuel/ign map adjustment when it senses a change in alcohol content to allow for the existing fuel mixture to be purged from the length of the fuel line.. A similar lag on the Sonic would mean the change in mixture would be combusting before the ECU made adjustments.
Does anyone think this should be a big concern?
