Stratton at 14.37.
-Eric Smit
My work hours have been ridiculous, so I haven't been able to do the leg work on what kind of female pin connectors I'll need to wire my alcohol sensor harness to the ECU. And I can't seem to get an answer here or from the vendors that would be involved.:blankface:
So I just ordered a ribbon cable harness online. I'll post the results when I get it figured out, so the next guy that is interested can just order whats needed and plug & play without all the time consuming PITA research.
I feel a little remiss here, but as I said, I didn't get anything special, I just ran over to a computer repair guy on my block and he had pins in his junk drawer that fit.
Unless you mean the end that fit into the sensor itself? That, I got from the same buick dealer that sold me the sensor in the first place. I got the whole wiring harness for it, but I imagine it might be possible to get just the plug end, I snipped the rest of the thing off, just kept wires long enough to get where I was headed.
The style needed to pin the ECU harness are:
Delphi E78 female pins. I'm ordering them today.
Thanks for the info Vince@Trifecta.![]()
That's awesome that you finally found someone to give up the info on the pins! If you make a spare harness/sensor set up or two I'm sure you can make a little money off of them.
Ethanol burns colder and resists detonation, allowing for more timing.
More timing, more power.
More ethanol, more timing, more power.
I know I'm speaking semantics, but ethical content doesn't directly create more power, rather it allows the engine to produce more power based on increased timing advance.
If anything, ethanol in itself, contains less power than gas per volume, that's why you have to burn a lot moe ethanol to see gains.
