Swordsmith
242hp/252 ft-lbs BNR EFI
I guess I don't get why people on here are trying to disprove me? Like you don't believe there is something wrong with my car.My wife has a Sonic, and hers works just fine. Worked everytime with her car--on the same inclines. Plus I purposely went to a very steep hill. Had same issues.
This is a much better report.
I am trying to disprove you because I know it can be tricky and that if it's the nut behind the wheel causing the problem, the dealer can't fix it.
But you are in an ideal situation to prove to yourself that it IS the car; if it works consistently in the same spot every time when you drive her car, doing the same thing (and with the same fuses in place) and doesn't work consistently on yours, then the problem is with your car, and the dealership needs to fix it, and if they don't you need to find another dealership.
If it never worked on your car, that would point to perhaps something to do with your mods. If it worked inconsistently on hers as well as yours, that would point to driver error or something. But this combo? It's really very clear that it's your car.
