Cabin Air Filter Changed... Original Filter!
Hey All. I ordered me a new Cabin Air Filter online on Amazon.com for a mear $21 shipped! My Dumba$$ Brother ordered it through a parts store and paid $56 to get his Cabin Air Filter lol.
Got mine today and Installed it into my Sonic this evening. I tell you, This was beyond Easy! Anyone, and i mean anyone can change this filter. Nothing to it.
opcorn:
Step #1 - Clear everything out of the Glove box, then just pop it right out by gentley squeezing the side walls inward and it pops right out.
Step #2 - Only thing holding it onto the car at this point is a little rubber hanger. Simply Unhook that from the glove box by sliding and wiggleing it off the post of the side of the glove box and the Glovebox is removed.
Step #3 - This is how i found it easier to see the box, Just sit down on the foot ledge of the passanger side door frame and look into the glove box area you just opened up. You will see a Black Unit, With a Door with a Diamond shaped Pattern on it. There are two clips on each side of it.
Simply squeeze them inward gently as with the glovebox and pull towards yourself. It will lift right upward giving you access to the Old Dingy Filter. Simply Slide that Filter out and Then Slide in the New Filter!
((ATTENTION:: Keep in mind how the old filter came out of that box. That is how you reinstall the new Filter.))
Step #4 - Re-installing everything back the way it was. Once the Filter is in, Simply Shut the door you opened, Press on each side Left and Right where the tabs you squeezed inward are to make the door snap into place. it will make a snap sound to let you know it is secure again. Once you have that done. now just re-install the glovebox. I will admit, this is by far the trickiest part of the whole installation. Listen up as i had a little bit hell from the glovebox when doing this part...
To re-install the glovebox. Start by getting the back of the Glovebox into the opening first so the rear of the box and the two Gromets on the side of the rear of the glovebox are inside the dash opening. Then set the bottom portion of the box down onto the base so that the teeth on the bottom of the glovebox sit into the grooves of the dash opening bottom. You will know what im talking about when you had it all disassembled. Just align that on the bottom and then slide the glove inward towards the windshield, then on the right side make sure to attach the little rubber gromet peice you removed to get the glovebox off and it should be back on now.
Im going to be changing my brothers Cabin Air Filter For him tomorrow so when i do his i will make a video of how to do this so that if my wall of text confuses anyone you can simply watch the video and see how to do it. He has around 31,000 miles on his Sonic and has never changed this filter so this should be interesting to see how it looks lol.
Pictures of my Stock Original Air Filter Below in the Attachments...
2012 Chevy Sonic LT Sedan - 13,885 Miles On the Original Cabin Air Filter...
