Swordsmith
242hp/252 ft-lbs BNR EFI
No, they were single pins, which is good because the pin outs on the ECU are in wildly different places.
I'm filling up, clearing trip ODO, filling up, doing the math.
It is possible I have a faulty injector, though, if you're getting much better numbers. Early on we thought that was the case but it seemed to clear up. Not really sure how to check!
I'd be very excited to see mid 30s on E85, I would never run anything else. Even at 23, it hurts me to go back to 93.
No, my numbers are not dyno proven, by the way, they are strictly UG report. I tried to set up a dyno but every one I could find was booked a month in advance, and I'm serving as taxi to a GF with some medical problems, very hard for me to predict that far off. She's doing much better now, I should give it another shot.
While I don't have dyno numbers, I can say that the best HP number I got from UG pre 85 was 180, and the best I saw on E85 was 230. So while they might not be accurate compared to another Sonic, due to the weirdness that is UG, that should be a relatively accurate picture of the gain.
Update on this project, since it keeps coming up.
Whole install went smooth, and Trifecta confirmed I am getting accurate fuel readings. I ran a wide variety of fuel mixes with no problems, and data logs were able to confirm a pretty close reading... I can't tell exactly what my mix is, because all fuels sold give only a range of possible alcohol content, 0-10% or 70-85%, so any given mix could only be within a certain range. Still, I ran everything from 7% to 16% to 40% to 80%, and lots and lots of tanks of E85.
Here's the skinny; E85 is not a monetarily efficient fuel. Under ideal conditions I was able to get as much as 27MPG, but normally I ran a solid 23mpg... and really pushing it, 22mpg. Same ideal conditions running 93 octane I got 44mpg.
While E85 is significantly cheaper per gallon than 93, it is not Half the price, while I get little more than half the MPG.
Also, when starting, on a cold day especially, E85 runs rough and ragged, it often stalls. This only lasts a minute or two, once the engine warms up it's smooth as any other fuel, once you get the tune dialed in. But it's a pain in cold weather.
On the plus side, it's capable of giving you a LOT more power. My UG got numbers as high as 230hp, my butt dyno says the difference is probably bigger than that. And it's capable of giving just as small amounts of power as any other fuel; use the accelerator gently and there's no difference between it and anything else.
I'm running 93 again now, in part because it helps make me feel good about doing the alcohol sensor, in part because I'm doing a lot of short trip runabout duty and this is much cheaper, and because in slippery weather the E85 is wasted, you can't lay down any real power on slick roads even if you wanted to.
If you want "racecar" power, E85 makes sense. Or if you're a crazy hippy who wants to save the planet by using less gas; I figure I was getting around 44miles per gallon of gasoline using E10 93, and I'm getting 153 miles per gallon of gasoline on E85. Lower pollution, better for the planet, so on and so forth.
For the casual driver looking to save a buck because E85 is priced even lower than that 87 crap, no, this isn't for you.
clutch first.
-Eric Smit
