Swordsmith
242hp/252 ft-lbs BNR EFI
Should be "racegas" lite, the higher the octane the faster the timing advance you can run without knock. E85 is the equivalent of 106 octane, which means you'd get a bigger boost running that, but if 100 is more available, and not crazy priced (you can get 110 for something like $10 a gallon...) then it would be a nice midway step, you wouldn't need the alcohol sensor, but you would need the upgraded injectors and I guess an improved tune, but not one as massively different as the E85/Flexfuel one.
