dbarrett231
I put it on the dyno today! This is with trifecta full tune ported intake manifold Bpv trick intake silicone intercooler tubes intercooler moved forward and catless down pipe and second cat delete dumped after the delete.
Thought I would post, see if I can get on "the list"... Just got done tuning with HP Tuners, not trifecta, we are running 16lbs on my 1.4t/6spd... Zzp Intake, 2.25" straight pipe and intercooler sprayer... We ended with 159hp/210trq! Going back to hit 18lbs to see how much more we can push it. Thanks guys!
I guess it's my turn to be told it's impossible for the stock tune to produce these numbers. We had a dyno day with the guys from CobaltNation. We were kinda rushed with the number of people we ran through the dyno. Krakenredbeard, Dangerfield007, and myself were minutes apart if anyone would like to compare.
We'll have better images when I get the email from the shop.
141whp 162wtq
-stock tune on 93 octane
-ZZP catback with resonator, no muffler
-modified air box
-boost bypass valve delete
Dyno was at 1000 ft elevation.
Assuming 14% driveline loss, that means 164hp and 188tq.
So when did this guy become a expert...... brass has bypassed the bypass valve for the recirc. Valve. This is what the vehicle uses to implement torque management....... so the numbers make sense. Also, it is not a fluke when multiple ppl. That dynoed in the same conditions said that there numbers were, on average, 10% lower on this dyno than others they have been too....
Thank you for posting! Again, good numbers for stock tune. The more of these we get, the better.View attachment 9412
Hard to see, but 150.6 whp, 181 tq on crappy gas, stock with tune from the guys at Diablo sport.
Stock was 128/148.
I don't expect to change the mind of a blind skeptic, but here are the facts.
First, the bypass is NOT the only thing done to my car. Second, there are several stock dynos showing hp numbers in the 130s. That is most certainly not a 30hp increase. Third, the numbers from the Trifecta Cruze were not corrected. It was also auto vs us with manual. These both contributed to the lower stock numbers as posted by Trifecta.
These are our dyno conditions.
90.89f 28.93in-hg 28%hum brasschucker
90.53f 28.93in-hg 29%hum kraken
90.57f 28.92in-hg 29%hum dangerfield
BIG changes
Everyone was STD corrected with 1.06 cf
The shop uses j607 which corrects to 60f 29.92in-hg 0%hum
Finally, I cannot afford to spend another $90 just to be told again that my numbers are too high. I will gladly accept donations if it means putting this issue to rest.
Stock was 128/148.
